hello, please tell me where to turn on the AI agent button to use so that you don’t have to press the button every time you request it.
Hey @Watcher_Official! Welcome to the n8n community!
If you want your workflow to be ‘active’ and do not need manual execute button to listen for triggers, you need to ‘publish’ your workflow on the top right you can see that button which says “Publish” click it! and done! Your workflow will be active and published which means it will be live and will listen for trigger events and will start the workflow whenever it triggers, and it will listen to triggers automatically!
I Hope this helps
Cheers!
and how can I stop to make adjustments?
Hey @Watcher_Official here
Hi @Watcher_Official let me know if you have any more questions.
You can mark it as the solution if you find it helpful.
