The script terminates with an error after 215 minutes of execution. At the same time, the server does not show any heavy loads. What can it be connected with - some restriction on the script execution time in the settings?
No errors, only this message in nodes “The execution was interrupted, so the data was not saved. Try fixing the workflow and re-executing.”
Good afternoon, Jon
There is nothing about timeout in the environment variables. Can you tell me where to look at the logs? There is no data in the nodes…
There is normally some kind of data it is a bit worrying that there is nothing at all. You can check the logs in the docker output unless you have it configured to log to file. Are you using anything like queue mode or is it just one instance.
