Toggle advanced options like pagination without losing configuration
The idea is:
Add an enable/disable toggle for advanced sections (like pagination in HTTP nodes), so users can temporarily deactivate them without losing the current setup.
My use case:
When debugging or testing a workflow, I sometimes need to disable pagination, authentication, or other optional configurations. Today, the only option is to delete the configuration, and if I want to re-enable it later, I must rebuild it from scratch.
It improves iteration speed and reduces friction when experimenting. Similar to toggling a node on/off, toggling internal sections allows for safe trial-and-error without impacting long-term settings.
Comparable UX pattern: feature flags or toggles in dev tools that allow temporarily disabling logic.
Not directly, but happy to review or help shape the UX if needed.
