Tool agent for RAG with structured output format
Hi team!
I would like to have a structured output from a RAG application using a tool agent. The RAG part works well (as long as “Require Specific Output Format” of the tool agent is disabled, everything goes as planned), but when requested a more structured response (by activating this option and adding a auto-fixing output parser, everything falls apart :face_with_thermometer:
output values have 5 keys, you must specify an output key or pass only 1 key as output
(I’ve got the same errors with other parsers)
  • n8n version: [email protected]
  • Running n8n via (Docker, npm, n8n cloud, desktop app): cloud
  • Operating system: Win 10
Thanks a lot for your help ! :smile:
Hey @Olivi Welcome!
I think it’s because you’re using a chat trigger where in the chat flow, it expects a certain response type for the user ie. A json object which looks something like this:
{ "output": "Certainly! The reason why ..." }
Change this to a manual trigger to see the difference.
If you still want to use an output parser, consider changing the “response mode” of the chat trigger to “Using the ‘response to webhook’ node” which allows you to do something with the agent’s response before sending it back to the user.
Thank you for your help!
