I’m trying to change the output of a shipping code to match what another vendors is. Currently I’m using a switch outputting to a set for each then merging the (3 soon to be 4). However I then have to use the always send data option which the sets are then placing the translation in the output vs all nulls.
Is there a way to only have it translate if the data element exists and sends it through? Or will a code element need to be used, and if so could I get an example?
Please share the workflow
My last element in my CSV is currently: ,,,,,,,,,,,,,,,,,,,,,,,FDXSO,
due to one being empty, I’m trying to get it to be all null or preferrably not put any data in at all.
- n8n version: Version 0.204.0
- Database you’re using (default: SQLite): SQLite
- Running n8n with the execution process [own(default), main]: Own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: n8n.cloud
