TH1
1
I have the below script in JavaScript and I want to convert to Python for it to work exactly.
// Get the API data
const apiData = $(‘Fetch Carpark Availability’).first().json.items[0].carpark_data;
// Get the CSV data (assuming the CSV node outputs an array of objects)
const csvData = $input.all();
// Since the CSV node might output multiple items (each row as an item), we need to collect them
let allCsvData = ;
for (let i = 0; i < csvData.length; i++) {
allCsvData.push(csvData[i].json);
// Create a mapping from carpark number to availability from API data
const availabilityMap = {};
apiData.forEach(carpark => {
availabilityMap[carpark.carpark_number] = carpark.carpark_info;
// Merge the data
const mergedData = allCsvData.map(carpark => {
const carparkNumber = carpark.car_park_no;
return {
...carpark,
availability: availabilityMap\[carparkNumber\] || \[\]
// Now, we need to return the merged data as multiple items or a single item with an array?
// Since we want to pass multiple carparks, we return each as a separate item.
return mergedData.map(item => ({ json: item }));
jabbson
2
Hey @TH1
It starts like this:
apiData = _("Fetch Carpark Availability").first().json["items"][0].carpark_data
csvData = _input.all()
and then it’s pretty much python as you know it. Use print statements to debug and documentation snippets:
and other places in the documentation where you can switch to python to see code examples.
TH1
3
Get the API data from the ‘Fetch Carpark Availability’ node
api_data = _(“Fetch Carpark Availability”).first().json[“items”][0].carpark_data
csv_data = _input.all()
Extract JSON from all CSV input items
all_csv_data =
for i in range(len(csv_data)):
all_csv_data.append(csv_data[i].json)
Create mapping from carpark number to availability
availability_map = {}
for carpark in api_data:
availability_map[carpark[‘carpark_number’]] = carpark[‘carpark_info’]
Merge the data
merged_data =
for carpark in all_csv_data:
carpark_number = carpark[‘car_park_no’]
Create a new dictionary with all properties from carpark plus availability
merged_item = {**carpark, ‘availability’: availability_map.get(carpark_number, )}
merged_data.append(merged_item)
Return each item as a separate item with json key
output = [{‘json’: item} for item in merged_data]
return output
TH1
4
actually when you use print() statement, where can we see the output?
jabbson
5
When you use print statement, the output is going to go to the developer’s web console
system
Closed
6
