Trigger Node Duplication and Workflow Navigation
The idea is:
To improve the workflow experience by adding a notification when trying to duplicate a trigger node, as well as a feature to help users locate nodes in large and chaotic workflows.
My use case:
I have a workflow with multiple nodes, and when I try to copy and paste a trigger node, I receive a pop-up warning about the copy. However, I cannot paste the node afterward. After some investigation, I realized that only one trigger node can respond to the click event. As a beginner, I find it difficult to notice this error.
Additionally, navigating large workflows is challenging, and I have not found a way to easily locate specific nodes, other than the “organize” button, which doesn’t fully solve the problem.
It would help beginners avoid errors when working with trigger nodes and make navigation easier in large, complex workflows. Adding a notification when duplicating a trigger node would prevent confusion, and having a search or filter option would greatly improve workflow management.
No specific resources, but this feature would improve user experience and workflow efficiency.
I am not able to work on this myself.
