I am having trouble creating the AWS file upload node with my credentials. I get a “forbidden error” My ID and secret are correct, but cannot login. Cn someone tell me how to correct this? Thanks!
You mean AWS S3
node right?
Usually it’s the account not having the right permission with the bucket
you try to upload.
Can you check about that again
Hi Darrell_tw, thanks for helping out. Yes, it was my credentials and I have corrected the error. Thanks again
