Hi everyone, i try to use template Joining different datasets,
but there are no input data in screen.
i start this template few times, but it is not helps, in output t i can see everything
Hi @Lali_Lorg Welcome to the community
Can you share some example data you’re trying to join, as well as your workflow? It’d be really helpful to have the data you’re trying to join in JSON format. For your workflow, can you share it by hitting ctrl/cmd + a and then ctrl/cmd + c on the workflow editor, and then pasting it here between two sets of three backticks (```)?
It’d also be helpful if you could give an example of what you’d have expected the data to look like, too.
