I’m building a multi-tenant SaaS for contractor businesses that needs to integrate with their CRMs (ServiceTitan, Housecall Pro, etc.). My architecture stores client OAuth tokens in Supabase (not in n8n’s credential system) and passes them to n8n workflows at runtime via webhook payloads. n8n never stores the tokens, just uses them for API calls during execution.
My questions:
Does this architecture comply with the Sustainable Use License, or does passing client OAuth tokens at runtime still require an Embed license?
If this requires the Enterprise plan, what’s a viable alternative? Using API keys for CRMs that support them? Building a different token management approach? Limiting to only CRMs with API key auth?
If I have to go single-tenant, how do experienced n8n developers manage updates/maintenance across 30+ instances without drowning in manual work?
- n8n version:
- Database (default: SQLite):
- Operating system:
