Hi All, I am having trouble posting my blocks to slack. I am not sure whether to put the JSON in the text post field, or if I need to format the post within slack. I currently have a JSON blob that I’ve validated in the Slack block builder but I keep getting errors when I try to post with blocks, and if I use the text field it just posts the JSON to the slack channel without formatting it. Any ideas? I am adding the workflow here:
"name": "Gdrive Playbook Notifier",
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
-240,
570
"parameters": {
"channel": "cse-updates",
"text": "=",
"attachments": [],
"otherOptions": {},
"blocksUi": {
"blocksValues": []
"name": "Slack",
"type": "n8n-nodes-base.slack",
"typeVersion": 1,
"position": [
1910,
770
"credentials": {
"slackApi": "n8n Bot"
"parameters": {
"triggerTimes": {
"item": [
"mode": "everyWeek",
"hour": 13
"name": "Cron",
"type": "n8n-nodes-base.cron",
"typeVersion": 1,
"position": [
-80,
579
"parameters": {
"functionCode": "var curr = new Date;\nvar first = (curr.getDate() - curr.getDay()) +1;\nvar last = first + 4;\n\nvar firstday = new Date(curr.setDate(first));\nvar lastday = new Date(curr.setDate(last));\n\nbeginning_week = new Date(firstday.setHours(0,0,0,0));\nending_week = new Date(lastday.setHours(23,59,59,99));\n\nitems[0].json.from = beginning_week.toISOString();\nitems[0].json.to = ending_week.toISOString();\n\nreturn items;"
"name": "Start and end of week1",
"position": [
100,
579
"typeVersion": 1
"parameters": {
"values": {
"string": [
"name": "folder.scoped",
"value": "1gaswxsAZsquyG_IA9JL0ChBPZtLNCGaT"
"name": "folder.unscoped",
"value": "1B46TbHO-MkCCV1_nGoeuDouFjWkXgzk3"
"options": {}
"name": "Set PB Folder",
"type": "n8n-nodes-base.set",
"typeVersion": 1,
"position": [
280,
579
"parameters": {
"operation": "list",
"useQueryString": true,
"queryString": "='{{$node[\"Set PB Folder\"].json[\"folder\"][\"unscoped\"]}}' in parents",
"options": {
"fields": [
"name": "Get Unscoped PBs",
"type": "n8n-nodes-base.googleDrive",
"typeVersion": 1,
"position": [
440,
780
"credentials": {
"googleApi": "TC Service Account"
"parameters": {
"queryString": "='{{$node[\"Set PB Folder\"].json[\"folder\"][\"scoped\"]}}' in parents",
"options": {
"fields": [
"name": "Get Scoped PBs",
"typeVersion": 1,
"position": [
470,
509
"credentials": {
"parameters": {
"values": {
"string": [
"name": "pb.creator",
"value": "="
"name": "pb.createddate",
"value": "={{$json[\"createdTime\"]}}"
"name": "pb.name",
"value": "={{$node[\"Split Scopes\"].json[\"name\"]}}"
"options": {}
"name": "Set scoped pb dict",
"typeVersion": 1,
"position": [
840,
349
"parameters": {
"keepOnlySet": true,
"values": {
"string": [
"name": "creator",
"value": "={{$json[\"owners\"][0][\"displayName\"]}}"
"name": "dateAdded",
"value": "={{$json[\"pb\"][\"createddatepretty\"]}}"
"name": "folder_name",
"value": "={{$json[\"name\"]}}"
"name": "link",
"value": "={{$json[\"webViewLink\"]}}"
"options": {}
"name": "Set unscoped pb dict",
"typeVersion": 1,
"position": [
980,
960
"parameters": {
"batchSize": 1,
"options": {}
"name": "Split Scopes",
"type": "n8n-nodes-base.splitInBatches",
"typeVersion": 1,
"position": [
650,
349
"parameters": {
"batchSize": 1,
"options": {}
"name": "SplitInBatches1",
"typeVersion": 1,
"position": [
610,
960
"parameters": {
"value": "={{$node[\"SplitInBatches1\"].json[\"createdTime\"]}}",
"dataPropertyName": "pb.createddatepretty",
"toFormat": "MMMM DD YYYY",
"options": {}
"name": "Date & Time",
"type": "n8n-nodes-base.dateTime",
"typeVersion": 1,
"position": [
800,
960
"parameters": {
"conditions": {
"number": [],
"boolean": [
"value1": "={{$node[\"SplitInBatches1\"].context[\"noItemsLeft\"]}}",
"value2": true
"name": "IF no more batches",
"type": "n8n-nodes-base.if",
"position": [
1290,
790
"typeVersion": 1
"parameters": {
"values": {
"string": [
"name": "slackupdateformatted",
"value": "={\"type\":\"section\",\"text\":{\"type\":\"mrkdwn\",\"text\":\"`{{$json[\"dateAdded\"]}}` *{{$json[\"folder_name\"]}}* _ Added by {{$json[\"creator\"]}}_\"},\"accessory\":{\"type\":\"button\",\"url\":\"{{$json[\"link\"]}}\",\"text\":{\"type\":\"plain_text\",\"text\":\"Google Folder\",\"emoji\":true}}}"
"options": {}
"name": "Build Slack Post",
"typeVersion": 1,
"position": [
1170,
960
"parameters": {
"functionCode": "const slackupdates = []\n\nlet counter = 0;\ndo {\n try {\n const items = $items(\"Build Slack Post\", 0, counter).map(item => item.json);\n slackupdates.push.apply(slackupdates, items);\n } catch (error) {\n return [{json: {slackupdates}}]; \n }\n\n counter++;\n} while(true);\n"
"name": "Merge Results",
"typeVersion": 1,
"position": [
1440,
770
"parameters": {
"functionCode": "let message = '';\n\nfor (const item of items[0].json.slackupdates) {\n message += `${item.slackupdateformatted},`;\n}\n\nreturn [\n {\n json: {\n message,\n }\n }\n];\n"
"name": "Create Message",
"typeVersion": 1,
"position": [
1590,
770
"parameters": {
"values": {
"string": [
"name": "slackmessage",
"value": "={\"attachments\":[{\"color\":\"#f2c744\",\"blocks\":[{\"type\":\"section\",\"text\":{\"type\":\"mrkdwn\",\"text\":\" :loud_sound: *IN CASE YOU MISSED IT* :loud_sound:\"}},{\"type\":\"section\",\"text\":{\"type\":\"mrkdwn\",\"text\":\"Replay our screening of *Threat Level Midnight* and pick up a copy of the DVD to give to your customers at the front desk.\"},\"accessory\":{\"type\":\"button\",\"text\":{\"type\":\"plain_text\",\"text\":\"Watch Now\",\"emoji\":true}}},{\"type\":\"divider\"},{\"type\":\"section\",\"text\":{\"type\":\"mrkdwn\",\"text\":\":calendar: | *UPCOMING EVENTS* | :calendar: \"}},{{$json[\"message\"]}}{\"type\":\"divider\"}]}]}"
"options": {}
"name": "Set",
"typeVersion": 1,
"position": [
1750,
770
"connections": {
"Cron": {
"main": [
"node": "Start and end of week1",
"type": "main",
"index": 0
"Start and end of week1": {
"main": [
"node": "Set PB Folder",
"type": "main",
"index": 0
"Set PB Folder": {
"main": [
"node": "Get Scoped PBs",
"type": "main",
"index": 0
"node": "Get Unscoped PBs",
"type": "main",
"index": 0
"Get Scoped PBs": {
"main": [
"node": "Split Scopes",
"type": "main",
"index": 0
"Get Unscoped PBs": {
"main": [
"node": "SplitInBatches1",
"type": "main",
"index": 0
"Split Scopes": {
"main": [
"type": "main",
"index": 0
"node": "Set scoped pb dict",
"type": "main",
"index": 0
"SplitInBatches1": {
"main": [
"node": "Date & Time",
"type": "main",
"index": 0
"Set unscoped pb dict": {
"main": [
"node": "Build Slack Post",
"type": "main",
"index": 0
"Date & Time": {
"main": [
"node": "Set unscoped pb dict",
"type": "main",
"index": 0
"IF no more batches": {
"main": [
"node": "Merge Results",
"type": "main",
"index": 0
"type": "main",
"index": 0
"Build Slack Post": {
"main": [
"node": "IF no more batches",
"type": "main",
"index": 0
"Merge Results": {
"main": [
"node": "Create Message",
"type": "main",
"index": 0
"Create Message": {
"main": [
"node": "Set",
"type": "main",
"index": 0
"Set": {
"main": [
"node": "Slack",
"type": "main",
"index": 0
"active": false,
"settings": {},
"id": "3"
