hi everyone
i faced twilio issue
i failed to get SMS
Can any one support me ?
regards
hi everyone
i failed to get SMS
regards
Hi, please share your workflow with the error message. Need to know how you configured the twilio node.
dear
i tool a course from indian tutor
all indian number was accepted
we have trying adding saudi numbers but not accepted
Hi, your workflow is correct. The issue seems stem of Saudi Arabia usage filter. After looking at twilio documentation they seem to encourage looking at the guidelines and registering a sender id.
You can read about it here: Saudi Arabia: SMS Guidelines | Twilio
Hope that helps!
thanks, i will check with them and feed you back very soon
