Two-Factor Authentication Problem
Hello everyone !
I have a problem and I need your help. I use N8N via Railway. Today I redeployed and when I log in again it doesn’t allow me to log in.
Neither the Authenticator app code nor the recovery code works, it simply appears that the code is not valid or has already been used.
Please help!!!
I checked my deployment logs, and found this:
error:1C800064:Provider routines::bad decrypt
Error: error:1C800064:Provider routines::bad decrypt
Anyone can assist me with this issue and how to resolve it ?
Hi @SeBraMarketing,
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
I haven’t used Railway to know this first hand but the error error:1C800064:Provider routines::bad decrypt in Railway suggests a decryption failure, often caused by an incorrect encryption key. Do you have the N8N_ENCRYPTION_KEY env var set?
