This does indeed sound like an issue with using the tunnel option. With ssh tunnel enabled the code creates a TCP proxy on the local postgres port, which becomes an issue when there are concurrent postgres node executions.
I’ll try to get a fix out next week.
Hello!
Yep, also using the tunnel
Hello, may I ask if there is any update here?
Hey @Fernand,
Yes, the below should fix this and it will be available in this weeks release.
Awesome! Thanks a lot for taking care!
New version [email protected]
got released which includes the GitHub PR 9906.
Hello,
I still have the following issue:
n8n version 1.50.0 (Cloud)
Error: All configured authentication methods failed at doNextAuth (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/client.js:865:21) at tryNextAuth (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/client.js:1082:7) at USERAUTH_FAILURE (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/client.js:430:11) at 51 (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/handlers.misc.js:408:16) at Protocol.onPayload (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/Protocol.js:2059:10) at AESGCMDecipherNative.decrypt (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/crypto.js:987:26) at Protocol.parsePacket [as _parse] (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/Protocol.js:2028:25) at Protocol.parse (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/protocol/Protocol.js:313:16) at Socket.<anonymous> (/usr/local/lib/node_modules/n8n/node_modules/ssh2/lib/client.js:775:21) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:488:12) at addChunk (node:internal/streams/readable:559:12) at readableAddChunkPushByteMode (node:internal/streams/readable:510:3) at Socket.Readable.push (node:internal/streams/readable:390:5) at TCP.onStreamRead (node:internal/stream_base_commons:191:23) at TCP.callbackTrampoline (node:internal/async_hooks:130:17)
This would imply that the SSH auth is wrong. Can you use the same SSH credentials with an SSH or SFTP node?
I got myself whitelisted to our Bastion server and could properly connect; I used the same credentials, user, and key on n8n and have the issue; I also whitelist those IPs: Cloud IP addresses | n8n Docs but still have an issue to connect.
What I meant was: Have you tried using the same credentials on a SSH node in n8n. If the same key works for SSH node, but not for postgres tunnels. then we have a bug that needs to be investigated.
I created a “ssh command” where I used the same credentials/ip and I could connect and execute a basic “ls -la” command.
@netroy Hi, now I can’t connect anymore to the database via ssh. My old and new database credentials throw the error “Couldn’t connect with these settings
Connection refused”. I am using Privatekey/Passphrase and I turned on “Ignore SSL Issues”
The n8n SSH credentials are working fine though.
I am using N8N Cloud 1.50.1.
@Fernand do you also have the “Ignore SSL Issues” flag enabled?
Can you folks share a screenshot of your postgres crendentials? That might help see any common patterns here.
I think I figured out the issue. Can you folks please try using the docker image n8nio/n8n:fix-ssh-tunnel
to see if this fixes the issue for you?
Hi, thanks this version works again!
Thanks for confirming. We’ll get this merged tomorrow, and then create a new patch release.
got released which includes the GitHub PR 10148.
