Hi there - I am stuck at 69% after taking the test mutliple times. I dont get what I could be interpreting wrong. Only having issues with the theory, can you help/ shed some light ? dc4c25d612c1a1e5cc2fe406a3d773dd
Hello,
If you’re having problems passing the quiz. Here’s a tip:
Some of the questions have multiple answers. You must select all correct answers for that question. You can tell which ones have more than one answer when the quiz doesn’t automatically go to the next question after you select an answer.
cheers,
I’m also stuck 77% on the first part, took multiple times, there’s no feedback on what I’m missing. I’ve tried searching for answers and there’s nothing out there to help other than “keep trying” and after 6 attempts, I’m not getting anything from this quiz. I’m just going to skip to the next course. stupid stickers.
Ok, so I’ve been going through the questions one by one and changing answers to see if my score goes up or down. I’ve never been able to get higher than 77% on theory. I always get 100% on the workflow portion. So, this time, it told me I “passed” the quiz with 62% on theory and 100% on the workflow portion! Something is seriously wrong with this quiz. I would love to work with someone at n8n on this to help improve the experience for users, as it is incredibly daunting to have this kind of experience right out of the gate and you are going to lose a lot of people on this. @jamiemadden_n8n or any other n8n mods, please contact me so I can share and we can improve this, thank you!
I’ve checked your answers and there are a couple of questions where you’re not selecting all the required answers or the correct answers for those.
I’ve added hints so that when more than one answer is required, it will say this on the question.
We have decided to not expense too much time updating these courses as we are working on a whole new set of learning pathways, that will be hosted on a full learning management platform. This will provide a much more fluid experience for the courses and the examinations.
Please give us some time to work on these new courses and provide a better experience for everyone.
cheers,
Amazing, thank you @jamiemadden_n8n! Is it possible for me to DM you? I am still unclear why I passed with only 62%. I completely understand everything you’ve said and am grateful for the feedback, thank you!
The pass on 62% was a bug that was fixed a few hours after you got that email. It looks like you have now passed and badge has been assigned.
Thanks! Yes, the bugged “pass” is what gave me the badge, but I still wish I knew what the right answers were, just for my own edification
Unfortunately, I can’t get any new scores/grades when I take the test now that I’ve “passed,” so I’ve just moved on to course 2. Which is fine. It’s time to move on ![]()
Hi @jamiemadden_n8n , Im stuck with the quiz at 77% too. Took the test several times and same result (even thought i checked the answers several time ) could you please check /help me out with this ?
2290f85900c25bf772f75d8962f5ec89
Thank you ![]()
I checked your results and can see that you are not answering some questions with all the required answers. Please double check them. Also I noticed some of your true/false answers you switched them from previous attempts when they were correct before.
cheers,
I did the test many times and different variations because I have no clue how high my percentage is or if there is a bug. Especially the theoretical part I really can’t find another error and in the practical one neither only thing I am not sure about if the second parameter condition and the first are connected by AND or OR. Happy to continue learning and give it another try but pretty hard if there isn’t a percentage or anything saying if I am close to scoring 80% ![]()
hi @jamiemadden_n8n could you pls have a check on my level one quiz result, my unique id is: c3bb71ed21724ef32b210cee8efd43c0, I stopped received the result email after 5th attempt
Hello,
Your course progress has been updated and verified. Your badge has been assigned.
cheers,
Hi, i’m also getting a bit confused now after the xth try. Can you have a look please and give me a hint in DMs what i’ve been doing wrong? My ID is 5c86668e49033dc9cb24b3cad2d56387
Thanks!
Hello, I’ve taken the tests a few times and the result is always the same:
“You obtained 77% in the theoretical section and 89% in the practical section”
My ID is 0aa3a5adcc838db22b74570271ac6db1
Sorry for hijacking this topic, but before relying on waiting for email to see if your ID is on the list as PASSED check this VERIFY COURSE LINK if your passed.
Cheers!
P.S @mais1alex your ID seems OK..
@Daniel.k96
you still need to try
A hint will be , that several answers are needed for some questions, and the flow will get forward by itself when you choose all the correct answers from options.
My last attempt, which is in the email, resulted in 77/89.
Anyway, I kept trying.
Thank you.
hi @jamiemadden_n8n could you pls have a check on my level TWO quiz result, my unique id is: c3bb71ed21724ef32b210cee8efd43c0, I did not received any email after my 1st attempt
Hello @Parintele_Damaskin could you provide a verify course link for Level TWO, i encountered the same issue after completing Level TWO QUIZ
I am on the same boat here, the theory score of my level 1 quiz always stays at 77% in different attempts of my test even though I tried with different answers. Can you please help me check?
My ID is 51ce28f54abfdb38696f6e0722a290ec
Thank you.
