Hey everyone
I test this same workflow with two different n8n Self hosted and the error keep appear when I add one http request node my workflow doesn’t save
What is the error message (if any)? 413
- **n8n version:1.192.0
- Running n8n via [Docker]:
Hi @mamprim, welcome to the community and I’m really sorry for the trouble you’re having.
Are you by any chance running n8n behind a reverse proxy server (or any kind of network component) enforcing a max request size?
You could double-check this by trying to save the same workflow on your local machine (docker run -it --rm -p 5678:5678 --name n8n n8nio/n8n:0.192.0
would start a local n8n temporary instance).
I’ve Found the problem… I was send a video in base 64 and was too long, My workflow just crashed…
But I figure out another way to do the same thing.
Anyway. Thanksss n8n is amazing
Glad to hear, thx so much for confirming!
