Hi everyone,
I’m trying to verify incoming webhook requests from GoHighLevel in n8n. These webhooks include a header called x-wh-signature
, which contains a digital signature of the raw request body, signed with a public RSA key (not HMAC).
The goal is to verify the integrity and authenticity of the payload using the provided public key and the raw body.
GoHighLevel’s official documentation:
Webhook Authentication Guide | Integrations API
The issue:
n8n doesn’t currently support verifying signatures using a public key (as in crypto.verify()
) inside the Crypto or Code nodes. Here’s what I’ve tried so far:
Solutions Attempted:
- Webhook node with Raw Body enabled
- Enabled
Raw Body
and tried accessing it via$binary.data.data
. - Used
Extract from File
andSet
nodes to decode and stringify the body. - Result: Either the body was
null
or altered, breaking signature validation.
- Crypto node (HMAC, Hash, Sign, etc.)
- Tried all available options:
HMAC
,SHA256
,Sign
— none supportverify
with a public key. - Could not recreate the correct signature using these methods.
- Code node using Node.js
crypto
module
- Attempted to use
crypto.createVerify()
— butcrypto
is not available inside the n8n Code node sandbox.
- JWT node
- Tested JWT node as a workaround but it’s not relevant — GoHighLevel is not sending a JWT.
- Header Auth on Webhook node
- Not usable in this case since it’s not a static header value but a cryptographic signature.
Environment:
- Webhook source: GoHighLevel
- n8n version:
1.82.3
- Database: SQLite (default)
- EXECUTIONS_PROCESS: own
- Running via: Docker
- OS: Ubuntu 22.04 (DigitalOcean droplet)
Next Step (Possible Solution):
As a workaround, I’m considering deploying a separate Node.js microservice (in Docker, side-by-side with n8n) to handle the RSA signature verification using crypto.verify()
. Once validated, it would forward the payload to another internal n8n webhook.
Before going that route, I wanted to ask the community:
Is there a native way in n8n to verify RSA signatures of raw webhook payloads using a public key?
Or has anyone implemented a similar flow?
Thanks a lot in advance!
