Hi!
Could you please explain what this error means (see screenshot). When I open this execution, there are no errors in any node.
If I retry execution, notification appears (screenshot #2)
Hi!
POST your flow please
Hi @roge, in addition to sharing your workflow, could you also confirm which version of n8n you are running and how you have deployed n8n? These details should be part of the template when posting a new question on the forum and can be really helpful in understanding the context of a problem, but it seems you have deleted them.
Thank you!
