I keep getting an issue that has no explanation. After 2h of execution suddenly, it fails with no logs, no error message:
(Im on cloud n8n)
Any idea on the reason or the solution?
(Im on cloud n8n)
Try to install n8n on your local PC from github, import there this workflow and check logs in terminal. Maybe u will find a problem…
