[Urgent] n8n docker, self-hosted instance restarting every 3-8 minutes
Hi @MutedJam , i’m unable to do so because those workflows are critical for a few business operations, and i don’t know how to implement a workaround for IMAP triggers in n8n, without the Imap node.
Kindly share if you do know of something for that.
fyi did some googling. Looks like it gets caused by the imap node and the library we are using:
Should be possible to catch this error and then do a reconnect.
Did commit a possible fix:
Will be released with the next version.
Got released with [email protected]
Hey @shrey-42 Jan implemented a fix, could you test if it solves the issue you were having?
Screen Shot 2022-06-18 at 07.27.51
I have made the changes according to this but still getting this somewhat ambiguous error.
However, other than IMAP, I am also using kafka trigger.
