Use another port for installation with docker compose
Hi dear friends
In my Linux server I installed “appwrite” with docker compose so my port 80 and 443 are allocated.
I try to install n8n on port 8080 for http and 444 for ssl.
This is my docker-compose.yml file
version: "3"
services:
  traefik:
    image: "traefik"
    restart: always
    command:
      - "--api=true"
      - "--api.insecure=true"
      - "--providers.docker=true"
      - "--providers.docker.exposedbydefault=false"
      - "--entrypoints.web.address=:80"
      - "--entrypoints.web.http.redirections.entryPoint.to=websecure"
      - "--entrypoints.web.http.redirections.entrypoint.scheme=https"
      - "--entrypoints.websecure.address=:443"
      - "--certificatesresolvers.mytlschallenge.acme.tlschallenge=true"
      - "--certificatesresolvers.mytlschallenge.acme.email=${SSL_EMAIL}"
      - "--certificatesresolvers.mytlschallenge.acme.storage=/letsencrypt/acme.json"
    ports:
      - "8080:80"
      - "444:443"
    volumes:
      - ${DATA_FOLDER}/letsencrypt:/letsencrypt
      - /var/run/docker.sock:/var/run/docker.sock:ro
  n8n:
    image: n8nio/n8n
    restart: always
    ports:
      - "127.0.0.1:5678:5678"
    labels:
      - traefik.enable=true
      - traefik.http.routers.n8n.rule=Host(`${SUBDOMAIN}.${DOMAIN_NAME}`)
      - traefik.http.routers.n8n.tls=true
      - traefik.http.routers.n8n.entrypoints=web,websecure
      - traefik.http.routers.n8n.tls.certresolver=mytlschallenge
      - traefik.http.middlewares.n8n.headers.SSLRedirect=true
      - traefik.http.middlewares.n8n.headers.STSSeconds=315360000
      - traefik.http.middlewares.n8n.headers.browserXSSFilter=true
      - traefik.http.middlewares.n8n.headers.contentTypeNosniff=true
      - traefik.http.middlewares.n8n.headers.forceSTSHeader=true
      - traefik.http.middlewares.n8n.headers.SSLHost=${DOMAIN_NAME}
      - traefik.http.middlewares.n8n.headers.STSIncludeSubdomains=true
      - traefik.http.middlewares.n8n.headers.STSPreload=true
    environment:
      - N8N_BASIC_AUTH_ACTIVE=true
      - N8N_BASIC_AUTH_USER
      - N8N_BASIC_AUTH_PASSWORD
      - N8N_HOST=${SUBDOMAIN}.${DOMAIN_NAME}
      - N8N_PORT=5678
      - N8N_PROTOCOL=https
      - NODE_ENV=production
      - WEBHOOK_URL=https://${SUBDOMAIN}.${DOMAIN_NAME}/
      - GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
    volumes:
      - ${DATA_FOLDER}/.n8n:/home/node/.n8n
      - /local-files:/files
So my problem is when I try to go to my console by my IP address:
https://myip:5678
It show below error:
Check your Internet connection
Check any cables and reboot any routers, modems or other network devices you may be using.
My question is:
Can I use another port for running n8n on my server and also does I have any mistake on my installation.
Hey @mooghermez,
That compose file has n8n listening on 127.0.0.1:5678 which local loop back only so you wouldn’t be able to connect using the ip unless you ran that from the host machine and use 127.0.0.1.
Luckily though you have changed Traefik to use port 444 and 8080 which should be running, can you try https://ip:444 and see if that works. You may need to check the docker logs for both containers to make sure they are working as well.
Hi dear jon
I edit docker-compose.yml file:
version: "3"
services:
  traefik:
    image: "traefik"
    restart: always
    command:
      - "--api=true"
    ports:
      - "8080:80"
      - "444:443"
    volumes:
  n8n:
    image: n8nio/n8n
    restart: always
    ports:
      - "5678:5678"
    labels:
    environment:
      - N8N_PORT=5678
    volumes:
now:
when I use below address:
https://myip:444
https://myip:8080
it return below error:
404 page not found
and when I use https://myip:5678 it return:
This site can’t be reached
myip unexpectedly closed the connection.
Try:
ERR_CONNECTION_CLOSED
Reload
details:
Check any cables and reboot any routers, modems, or other network devices you may be using.
Allow Chrome to access the network in your firewall or antivirus settings.
If it is already listed as a program allowed to access the network, try removing it from the list and adding it again.
If you use a proxy server…
Check your proxy settings or contact your network administrator to make sure the proxy server is working. If you don’t believe you should be using a proxy server: Go to the Chrome menu > Settings > Show advanced settings… > Change proxy settings… > LAN Settings and deselect “Use a proxy server for your LAN”.
Hey @mooghermez,
There is no need to change the port n8n listened on what you have now is a configuration that would allow 5678 to be used bypassing Traefik.
Have you checked the docker logs to see if they show the services are running? I suspect either the containers are not running or you have a firewall / network issue.
