Use Case Layout / Design
Is there a prefered app or process in N8N for quick layout of concepts before actually building the workflow?
I personally design the concept with the nodes directly on n8n also to understand which nodes are already present and which are not.
I draw it without connections or prompts but only to understand if logically everything is ok.
