I’m new to n8n and trying to understand the proper use cases for a few key data manipulation nodes, specifically Merge, Split Out, Aggregate, and Summarize.
I’m working on a workflow that pulls user data from two different sources. The first source returns a JSON array of user profiles, and the second source returns a corresponding JSON array with detailed contact information for those users.
My goal is to:
- Combine the user profile and contact information based on a common
userId
. - Count the number of users from each city.
- Split the combined, enriched user data back into individual items so I can process them one by one (e.g., send an individual email to each user).
- (Optional) Calculate summary statistics for a numeric field for each user, like
totalSpent
I’ve tried different combinations of these nodes but I’m unsure which node is the best practice for each scenario. For example, should I first use the Merge node and then the Split Out node, or is there a more efficient way? What is the core difference between Aggregate and Summarize when it comes to counting and calculations?
I’d appreciate it if someone could clarify the ideal scenarios and workflows for using these powerful nodes.
There is no error message. This is a question about best practices and conceptual understanding.
“nodes”: [
“parameters”: {
“fieldsToAggregate”: {
“fieldToAggregate”: [
“options”: {}
“type”: “n8n-nodes-base.aggregate”,
“typeVersion”: 1,
“position”: [
-1740,
2060
“id”: “1e777687-d648-44b7-ac74-77967269b785”,
“name”: “Aggregate10”
“parameters”: {
“options”: {}
“type”: “n8n-nodes-base.splitOut”,
“typeVersion”: 1,
“position”: [
-1300,
2040
“id”: “f84ad7f0-369c-45e8-ba77-b99bb440d993”,
“name”: “Split Out4”
“parameters”: {},
“type”: “n8n-nodes-base.merge”,
“typeVersion”: 3.2,
“position”: [
-1080,
2040
“id”: “ec9af05f-0a46-4967-9705-7f2372db3069”,
“name”: “Merge3”
“parameters”: {
“fieldsToSummarize”: {
“values”: [
“options”: {}
“type”: “n8n-nodes-base.summarize”,
“typeVersion”: 1.1,
“position”: [
-860,
2040
“id”: “589c72d2-0837-4c8a-a3b5-29f14c219978”,
“name”: “Summarize3”
“connections”: {
“Aggregate10”: {
“main”: [
“node”: “Split Out4”,
“type”: “main”,
“index”: 0
“Split Out4”: {
“main”: [
“node”: “Merge3”,
“type”: “main”,
“index”: 0
“Merge3”: {
“main”: [
“node”: “Summarize3”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “b914b727c7e48e90b2806df064caf0a1601e762e5d73b65a3ed2ae68c9e0f94b”
none
- **n8n version:1.95.3
- Database (default: SQLite):
- **Running n8n via (Docker, npm, n8n cloud, desktop app):**npm
- **Operating system:**windows
