Use external authentication possible?
From what I can see when reading the documentation, there is currently no way to replace the internal n8n authentication with a more robust external ‘corporate/enterprise level’ solution. Preferable with OIDC, but optionally even using reverse proxy based authentication (like Traefik + Okta).
Is my conclusion correct? If so, is there a way to vote for such a feature?
hello @crazyelectron-io
Enterprise plan has LDAP/SSO integration
Ah, I was not aware. Thanks.
