Using Agent in n8n to Clean Non-Numeric Values in Postgres
Hi Community :waving_hand:,
I’m trying to build an agent-based workflow in n8n that works with my Postgres database.
Here’s my goal:
  • Work inside a specific database and table.
  • Fetch all rows.
  • Analyse one specific column.
  • If any value in that column is non-numeric, update it to 0.
  • Finally, validate that all values are numeric after the update.
I see that the Postgres nodes allow:
  • Select rows from Postgres in a table
  • Insert_or_update_rows_in_a_table_in_Postgres
But I’m not sure how to best structure the agent prompt/workflow so that the agent:
  1. Selects all rows,
  2. Checks for non-numeric values in the chosen column,
  3. Applies updates using the insert/update node,
  4. Validates again at the end.
Has anyone implemented something similar with n8n Agents + Postgres?
Any guidance, examples, or best practices would be super helpful :folded_hands:
Thanks in advance!
