Using an OpenAI-Compatible Endpoint in n8n to Switch Between LLM Models
When building LLM workflows in n8n, one small problem shows up pretty quickly:
You set up a workflow with one model, test it, get it working, and then later realize you want to compare it with another model. Maybe you want a cheaper model for classification, a stronger one for reasoning, or simply want to test how different model families perform on the same input.
If the workflow is tied too tightly to one provider-specific node, switching models can become annoying fast.
So I wanted to share a simple pattern I use: call an OpenAI-compatible endpoint through the HTTP Request node, and keep the model choice flexible.
Disclosure: I am on the TokenBay team, so the example endpoint below uses TokenBay. The same general workflow pattern should also work with other OpenAI-compatible endpoints.
Use case
Let’s say you have an n8n workflow that sends customer text to an LLM and expects a structured response back.
For example, you may want to:
  • summarize a customer message
  • classify the user intent
  • extract key information
  • route the result to another node
Later, you may want to test different model families without rebuilding the whole workflow.
Basic HTTP Request setup
Create an HTTP Request node in n8n.
Use the following setup:
  • Method: POST
  • URL: https://api.tokenbay.com/v1/chat/completions
  • Authentication: header auth or custom headers
  • Header: Authorization: Bearer YOUR_TOKENBAY_API_KEY
  • Header: Content-Type: application/json
Example JSON body:
json
"model": "gpt-5.4-mini",
"messages": [
"role": "system",
"content": "You return concise JSON."
"role": "user",
"content": "Summarize this customer message and classify the intent: {{$json.message}}"
This keeps the setup close to the standard OpenAI Chat Completions format, which makes the workflow easier to move, test, or adjust later.
Switching models
To test another supported model, you can keep the same HTTP Request node and change only the model value.
For example:
json
"model": "claude-sonnet-4.6",
"messages": [
"role": "user",
"content": "Summarize this customer message: {{$json.message}}"
That means the overall n8n workflow does not need to change. The input structure, HTTP node, downstream parsing, and routing logic can stay the same.
In a production workflow, I would avoid hardcoding the model name directly in every node. A cleaner approach is to store the model name in a variable, environment setting, or earlier configuration node, then reference it inside the request body.
For example, the model field could be handled as something like:
json
"model": "{{$json.model}}",
"messages": [
"role": "user",
This makes it easier to test changes without editing multiple nodes manually.
Why this can be useful
This pattern is useful when you want to keep your n8n workflow provider-flexible instead of locking the logic too early.
A few practical examples:
  • use a cheaper model for simple classification
  • use a stronger model for reasoning-heavy tasks
  • compare model quality on the exact same workflow
  • keep one billing/key flow while experimenting
  • avoid rebuilding provider-specific nodes before you know what model works best
It is not a complicated setup, but that is the point. For many LLM automations, keeping the model layer easy to swap is more valuable than over-engineering the workflow from day one.
Things to check
Before using this pattern seriously, check a few things for whichever endpoint you use:
  • pricing
  • timeout behavior
  • model availability
  • rate limits
  • data and privacy policy
  • response format consistency
Example link:
The homepage currently lists 500 free credits, 15% off most models, and referral credits, which should be enough to try a small workflow test before committing real usage.
Would love to hear how other n8n users are handling model switching across LLM providers.
Good pattern. I do something similar in my own workflows, one HTTP Request node with the model name as a variable, so switching between Groq, Gemini and Claude is one config change instead of rebuilding nodes.
One thing worth adding: response format consistency between providers is the part that bites you most when switching. OpenAI-compatible endpoints generally return the same structure, but small differences in how models handle system prompts or JSON mode can break downstream parsing. Worth building a normalization step early so the rest of the workflow doesn’t care which model ran.
What has your experience been with rate limit behavior across providers on TokenBay? That’s usually where unified APIs diverge the most from direct provider calls.
Nice pattern. One thing I would add for teams testing any OpenAI-compatible endpoint in n8n is to separate the first-call smoke test from the workload evaluation.
My usual checklist:
1. verify the exact base URL and model route
2. run one minimal /v1/chat/completions request
3. log status code, request ID, latency, and response shape
4. only then run 10-20 real workflow tasks
5. compare useful output, failure rate, retries, and spend per successful task
Disclosure: I work with modelrouter.site, an independent third-party OpenAI-compatible gateway. Not an official model-provider service.
If useful, here is the checklist URL I use for first-call testing:
_n8n_endpoint
