Hey. So I’m using a http request node.
When I try to use data from the previous node as “{{ $json[‘request’][‘image_base64’] }}” it fails and gives me Bad request - please check your parameters warning.
But if I just paste the base64 image directly as a string the request works.
What can cause this?
- n8n version: 1.41.1 (Self Hosted)
- Database (default: SQLite):
- Operating system:
