Using Fastmail
Is there anyone using Fastmail.com for an smtp node?
Hey @Account_Support ,
What is your issue ?
Thank you for your reply. I am switching to the AWS.
That’s not the issue
I realize that. I am no longer going to use fastmail. This question is no longer required.
If you are still curious - I do not know of a way to use Fastmail with the traditional SMTP functionality, but with the JMAP API, this example may be helpful.
I was able to solve the issue. The email DNS setting was not correct. It’s working 100% now.
