Dear sirs,
Is it possible to use a n8n NODE as Microsoft Powerapps Datasource, as if it would be a native connector?
Do you know any low-code alternative to Microsoft Powerapps, that works natively with n8n?
Thank you!
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
- n8n version:
- Database you’re using (default: SQLite):
- Running n8n with the execution process [own(default), main]:
- Running n8n via [Docker, npm, n8n.cloud, desktop app]:
