Environment
Railway deployment of n8n with the template.
Requirements
- will be using it as the backend engine and building the UI on top of that in vuejs
- also, will be managing users and other details at my own DB
Doubts
- What all APIs do I get access to
- workflow execution
- single node execution
- workflow history
- concurrent executions
Notes:
I am open to buying the plans, if required but just curious to find out which one will work the best for me.
Here you can find a comprehensive list with all the API in the docs section :
Eg:
what if I want to have the api to execute a single node or a sub workflow.
also, if I self host in railway, then what will be the limits of execution - both per month and concurrent.
and curious to what I will get when I will self host. like what is the difference in terms of using self hosting or their hosting.
This post covers the license part :
About Executing one node in a workflow via API… can’t help with that.
system
Closed
5
