I’m creating a cookie using an endpoint and want to use that value in a Header Auth - Generic Credential Type.
I need to keep using this custom Generic Credential, which has a cookie generated dynamically from the previous step, for a complete execution and task as I invalidate this cookie at the end of the workflow.
How can I put a value from a previous step into a generic credential?
