Value is not a valid record ID
Hi everyone,
I think I’m losing my mind on this one.
I’ve been trying to make an Airtable Upsert work for hours and I’ve literally tried everything.
I keep getting the same error, even after completely removing the field it refers to.
:puzzle_piece: The error
Your request is invalid or could not be processed by the service
Value “https://example.com” is not a valid record ID.
The weird thing is:
  • The field I’m mapping this value to is a plain text field (not a linked record).
  • The error still complains about “record ID”.
  • Even after removing the mapping for this field, n8n continues to show the same error — like it’s cached somewhere.
  • I even switched the column used in “Columns to match on” and refreshed the table schema, but the issue persists.
:gear: Context
Here’s roughly what I’m doing:
  • Operation: Create or Update (Upsert)
  • Base: (generic Airtable base)
  • Table: (generic table)
  • Columns to match on: a text field (Key)
  • Values being sent:
    • Key → canonical URL (string)
    • Client → { id: client_id } (linked record)
    • Project → { id: project_id } (linked record)
    • URLs → JSON string array
    • Hreflangs → JSON string array of objects
I’ve already tried:
  • Wrapping the expression in String()
  • Adding a Set node before the Upsert to force the value as plain text
  • Changing the table and switching back to force a schema refresh
  • Creating a new text column to match on
Still, I get exactly the same Value “https://…” is not a valid record ID message.
:sos_button: What I need help with
  • Has anyone else seen this “not a valid record ID” issue when using Upsert on a text field?
  • Is there a way to force n8n to send the value as a string, or clear cached Airtable field types?
  • Could this be a bug in how the Airtable node handles custom “Columns to match on”?
Thanks in advance — I’m really stuck on this and starting to go insane :sweat_smile:
