Values become undefined
When I run workflow it sometimes just sets Start’s node value to undefined (mostly first one)
No prompt specified
Expected to find the prompt in an input field called 'guardrailsInput' (this is what the guardrails node node outputs). To use something else, change the 'Prompt' parameter
This image shows how it looks like in editor
No prompt specified
Expected to find the prompt in an input field called ‘guardrailsInput’ (this is what the guardrails node node outputs). To use something else, change the ‘Prompt’ parameter
  • n8n version: 2.0.2
  • Operating system: Host: Docker (Alpine 3.22.2). Client: NixOS 26.05 (Yarara)
Exactly the same problem here.
I have the same issue with Anthropic
@Emmanuel44 @InScius try using first() instead of item inside of {{ }}. It helped me
