Vector dimension 1536 does not match the dimension of the index 512. I am not sure, why I’m receiving this error, I’m using pinecone and open ai text embedding 3 small to build a small RAG database retrieval demo workflow. ```
PineconeBadRequestError: Vector dimension 1536 does not match the dimension of the index 512 at mapHttpStatusError (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@[email protected]/node_modules/@pinecone-database/pinecone/src/errors/http.ts:150:14) at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/@[email protected]/node_modules/@pinecone-database/pinecone/src/errors/handling.ts:23:30 at step (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@[email protected]/node_modules/@pinecone-database/pinecone/dist/errors/handling.js:33:23) at Object.next (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@[email protected]/node_modules/@pinecone-database/pinecone/dist/errors/handling.js:14:53) at fulfilled (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/@[email protected]/node_modules/@pinecone-database/pinecone/dist/errors/handling.js:5:58) at processTicksAndRejections (node:internal/process/task_queues:95:5)
