Verified node live in editor — how does Best apps & software integrations | n8n directory listing work?
Hi! Our node @itservtechnology/n8n-nodes-itoc360 was recently verified and is now live in the editor.But there are two things i want to ask:
Question: will verified community nodes also get a listing page on the Best apps & software integrations | n8n directory? Is there anything required on our side, or does it sync automatically at some point?
Small bug report: the “Verified Nodes Feedback” survey linked from the verification notification email fails with “Could not get execution status — make sure ‘Save successful production executions’ is enabled in your workflow settings.” Tried twice in a clean browser session — flagging in case it’s broken for other creators too.
The verification process itself was smooth — docs were clear and the Creator Portal made everything transparent. Thanks!
