Vertex model chat model not found
UPDATE: FOUND A SOLUTION → The reason for this not working is because I needed to put the region on us-central1, once I did that it worked with any model I wanted
I am trying to use the vertex chat model node and connect it to an AI agent and I want to use the gemini 2.5 flash preview model (listed on Gemini 2.5 Flash  |  Generative AI on Vertex AI  |  Google Cloud Documentation)
However I receive an error saying the model is not found, same for gemini 1.5/2 or any other model.
No model found called ‘gemini-2.5-flash-preview-05-20’
“nodes”: [
“parameters”: {
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.chatTrigger”,
“typeVersion”: 1.1,
“position”: [
220,
0
“id”: “736eff2d-e590-4b92-bf11-e161e6e00310”,
“name”: “When chat message received”,
“webhookId”: “0aa4828f-cd8a-4bc5-a713-a3e89d5aa065”
“parameters”: {
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.agent”,
“typeVersion”: 2,
“position”: [
440,
0
“id”: “6ba934d2-9d7f-4cde-8025-782131aec331”,
“name”: “AI Agent”
“parameters”: {
“projectId”: {
“__rl”: true,
“value”: “dive-407815”,
“mode”: “list”,
“cachedResultName”: “Dive”
“modelName”: “gemini-2.5-flash-preview-05-20”,
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.lmChatGoogleVertex”,
“typeVersion”: 1,
“position”: [
440,
180
“id”: “78bcf3f8-84c9-4a1c-a534-42c4d956961e”,
“name”: “Google Vertex Chat Model”,
“credentials”: {
“googleApi”: {
“id”: “OuAOBcnGAmHSQ62I”,
“name”: “Google Service Account account”
“connections”: {
“When chat message received”: {
“main”: [
“node”: “AI Agent”,
“type”: “main”,
“index”: 0
“Google Vertex Chat Model”: {
“ai_languageModel”: [
“node”: “AI Agent”,
“type”: “ai_languageModel”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “379d193425f7661943a57a905552cfa2870b9e95bc1af1db348606ed80556ca8”
  • **n8n version: ** 1.0.7 from the helm repo -
  • **Database (default: SQLite): ** Postgresql
  • Running n8n via (Docker, npm, n8n cloud, desktop app): self host k8s helm chart
  • Operating system: linux
hi, so it’s solved now?
Yes it was. Pasting the solution here as well:
This problem still exist (Global region does not exist in N8N Credential settings)
The credential setup is not fully in sync with Google Vertex AI regions to choose from. The latest update on Gemini 2.5 pro with model name gemini-2.5-pro-preview-06-05 is ONLY available on the global region.
In the N8N Google Service Account API it is not possible to select a global region! So selecting gemini-2.5-pro-preview-06-05 is not possible with the Vertex Chat model. It will always result in an error.
Source:
  1. Deployments and endpoints  |  Generative AI on Vertex AI  |  Google Cloud Documentation
  2. Deployments and endpoints  |  Generative AI on Vertex AI  |  Google Cloud Documentation
@jpvanoosten, can your team put this on the backlog please? I would love to use the latest Gemini 2.5 Pro models using Vertex AI. Tnx!
