Hi everyone,
I build Vivere (https://vivere.dev), a heartbeat monitor, and I’ve published a community node for it: n8n-nodes-vivere.
The problem
The Error Workflow only fires when an execution fails. If a Schedule Trigger never fires (the instance was restarting at that minute, the workflow was deactivated after an import, a trigger quietly died), there’s no execution, so nothing reports it. A run that goes green but processes 0 items looks fine too. This comes up in threads here regularly.
Vivere watches from the outside: each workflow checks in when it runs, and if a check-in doesn’t arrive within the schedule plus a grace period, you get an alert.
5-minute demo
What the node does
- Ping → Start / Success / Fail: one ping per run, with the item count; it can report a run that processed 0 items as failed
- Monitor → Create: create the monitor from n8n
- AI runs: send the model, tokens and cost of a run, and Vivere alerts you when a run costs more than a limit you set
- Works as a tool for the AI Agent
Install
Settings → Community nodes → Install → n8n-nodes-vivere
Self-hosted for now: it’s in n8n’s verification queue, so not on n8n Cloud yet.
The free plan covers 25 monitors with email and webhook alerts, no card. Pro adds Slack, Discord, Telegram and ntfy, and the first 50 founding members get Pro for $5/month.
Source: GitHub - nicholasbergesen/n8n-nodes-vivere: n8n node for Vivere: get alerted when a workflow stops running, does nothing, or fails · GitHub
Guide: n8n · Vivere
Happy to answer questions or take feedback, including on what the node should do next.
