Changing the Workflow itself to UTC didn’t solve the problem.
I can’t change the whole of my N8N to UTC, there are too many workflows with time dependencies that would be broken.
Ah ha! Apologies for the terrible suggestion.
No, no worries! I was hopeful changing it in the workflow would work, so it was worth trying, and just posted to the team had that feedback so they could better diagnose & fix the problem.
If you are curious you can find the PR for this here: fix(Wait Node): Account for workflow timezone in Wait node datetime by ivov · Pull Request #8578 · n8n-io/n8n · GitHub it isn’t fixed yet but should be done soon.
