Wait node with on webhook call not working from the first short
I have a workflow with a wait node. The wait URL is https://n8n.*******/webhook-waiting/{{$executionId}}/processing-finished
However the execution get ended after calling the wait web-hook multiple times.
No message
Please share the workflow
No output
- n8n version:: 0.171.0
- Database you’re using (default: SQLite):: PostgreSQL
- Running n8n with the execution process [own(default), main]:: own I think (don’t know the difference)
- Running n8n via [Docker, npm, n8n.cloud, desktop app]:: Docker behind nginx reverse proxy
