Waiting for (Executing previous nodes) forever
i am facing a very strange problem in my first workflow created in my new cloud vps server, i am using docker compose it install n8n and nginx proxy manager and can access the n8n through https successfully, but in the workflow there is a problem that when starts with chat trigger and send a test chat message, the chat node receives the input and marked green but the next node (whatever it is AI Agent or other) did not receive any input from the previous chat node and keep the status of (Executing previous nodes) for a very very long time. really i don’t know what is the reason of this problem or how to solve it. any help or guid will be really appreciated.
Hi @egyptengineer
Can you try the same workflow on our Cloud? if it works there, might be some local setup issue.
Hope this helps!
