We are building a flow that interacts with the Zoho invoices upsert node, but when using it we get an unknown error.
There was an unknown issue while executing the node
Node type
n8n-nodes-base.zohoCrm
Node version
1 (Latest)
n8n version
1.83.2 (Cloud)
Time
3/26/2025, 8:17:21 AM
Stack trace
NodeApiError: There was an unknown issue while executing the node at ExecuteContext.zohoApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Zoho/GenericFunctions.js:55:15) at processTicksAndRejections (node:internal/process/task_queues:95:5) at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Zoho/ZohoCrm.node.js:438:40) at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:681:27) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:913:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1246:20
