I am trying to use API authentication to Webflow for a Webflow Trigger (new form submission) When reading the Webflow credential documentation it references an API access token authentication method, but there is no UI option for this.
Also, FWIW, the OAuth2 authentication did not work until I toggled OFF the “Legacy” toggle in the app—otherwise it errors on the “Site Name or ID” step where it says “Error fetching options from Webflow Trigger” so I cannot proceed to the next step. Turning this OFF fixed this error.
“nodes”: [
“parameters”: {
“site”: “65542e9a1d6c0446bbad1ed5”
“type”: “n8n-nodes-base.webflowTrigger”,
“typeVersion”: 2,
“position”: [
0,
0
“id”: “767c646d-7264-4b5c-b2fc-bd679871bb79”,
“name”: “Webflow Trigger”,
“webhookId”: “2e78171d-8809-410b-996e-dbdb76b3ac94”,
“credentials”: {
“webflowOAuth2Api”: {
“id”: “40zfvR8K6xzOf2J5”,
“name”: “Webflow Production”
“connections”: {},
“pinData”: {},
“meta”: {
“instanceId”: “2bcecbc07f2cf5a082a750fb41eb9a75144ea06fffbbb6e03b171cd8ae0e3a05”
- n8n version: 1.85.4
- Database (default: SQLite): SQLite?
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
- Operating system: Cloud - using latest macOS and latest Brave browser
