Webhook conflict two n8n same docker swarm
I’m trying to install a second n8n queue in the same docker Swarm, but when I upload the stack there is a conflict in the webhook of the two n8n, neither of them receive anything anymore, trying to send through postman returns (error 404), I’ve already tried changing the input port and exit, but nothing seems to solve it.
[image]
(error 404)
Stack Before
New Stack
I also installed a redis for each.
before redis
new redis
  • **n8n version:1.29.1(queue) and 1.31.0 (queue)
  • **Database (default: SQLite):POSTGRESQL
  • **Running n8n via :Docker Swarm
  • **Operating system:Ubunto 20
Hey @admdiegolima,
The n8n config mostly looks good to me, I suspect the issue could be with your reverse proxy and maybe it isn’t routing correctly or the labels are not working. Have you checked the logs in Traefik to see if it shows anything else?
was resolved by placing redis on separate volumes
