Webhook method in output
n8n version: 1.54.3
Database: SQLite
EXECUTIONS_PROCESS: main
Running: npm
OS: Ubuntu 22.04
How do I get the HTTP method in the output when the webhook is set to multiple HTTP methods without doing something like an edit field on each output? Cheers
hello @kickin6
Can you elaborate more of what you are trying to achieve?
I decided to use a webhook with a GET and POST outputs. Cheers
