Webhook not receiving messages from 360dialog – Workflow fails with "Problem running workflow"
Hey everyone,
I’m currently trying to connect WhatsApp messages from 360dialog to an n8n workflow via a webhook. The webhook URL is already registered in the 360dialog hub and is being called correctly – I can see the POST requests coming in from 360dialog when I test it.
However, the workflow fails and gives me a “Problem running workflow” error when the webhook is triggered.
hello @Forder_Fuchs
Can you please share the workflow?
You can select all nodes with ctrl+a, copy it with ctrl+c. Then past the content here after pressing button </> with ctrl+v.
ut just works after few traiings thank you men
can you help me with that? Can u share the workflow?
