Webhook not triggering with large base64 data
Hi,
I’m trying to send large (c.38mb) base64 encoded data to a webhook trigger. Each time I do nothing seems to happen. I don’t see any executions, fails, attempts, or anything. However, when I reduce the payload to around 5mb, everything works fine.
Am I hitting limits?
Thanks.
  • n8n version: @1.38.2
  • Operating system: Mac, Andorid, iOS, web (literally everywhere)
Hey @EnigmaXXIII,
Quick question: How are you sending the data? Is it via a URL? According to Stack Overflow, URLs have a limit of approximately 2000 characters.
Could you try sending it in the body using the POST method instead?
Hey @Shirobachi,
I am sending as a body request already. Here’s an example output that works when using a smaller file. Only change is file size…
