Webhook post body to array question
Hi everyone, i know this should be easy but for the life of me cannot figure it out
i have a webhook getting some data in the format below:
I’ve messed around with some functions code but can not figure it out, how do I get “jobData” into its own json array so it can be accessed easily
thanks in advance
Use the Item Lists node with body.jobData as the "Field To Split Out ".
If you can however, share your example data in a code block and/or include your workflow JSON.
After having a think about it some more it was an issue in PHP on how i was posting the data, i was using json_encode and not http_build_query($postRequest)
