Webhook routing/startup speed
I managed to get an instance of n8n running on the akash network!
Akash Forum Thread
I discovered that the workflow runs very quickly once it starts!
However, there is a 4 sec delay between “Started execution of workflow” and “Initializing n8n sub-process” Is there anything I can do on the workflow design or server setup that can avoid this long “internal routing” delay?
2021-06-21T06:31:16.518Z | verbose  | Started execution of workflow "My workflow" from webhook with execution ID 3
    {"executionId":"3","file":"WebhookHelpers.js","function":"executeWebhook"}
2021-06-21T06:31:20.394Z | verbose  | Initializing n8n sub-process
    {"pid":38,"workflowId":1,"file":"WorkflowRunnerProcess.js","function":"runWorkflow"}
2021-06-21T06:31:20.582Z | verbose  | Workflow execution started
    {"workflowId":1,"file":"WorkflowExecute.js","function":"processRunExecutionData"}
2021-06-21T06:31:21.342Z | verbose  | Workflow execution finished successfully
    {"workflowId":1,"file":"WorkflowExecute.js","function":"processSuccessExecution"}
Normally it takes like 1 second, so I guess the underlying system is slow. Like slow HD or to less CPU.
But even 1 second is slow. If you need a fast response, you should set the mode to main:
just found that and came here to update the thread ; )
surprisingly it is faster on gitpod than akash
