Webhook test-url not changing to production-url
Hi when I try change my webhook from test-url to production-url, it does not change, and remains on the test-url. I’ve set the status to “Active” but still doesn’t change.
  • **n8n version: 1.75.2
  • **Running n8n via (Docker]
  • **Operating system:Linux
Click on the “Production URL”.
webhook-test changes to webhook
Hi Franz,
Thanks for your response.
So the issue that I’m experiencing, is that if start on Test URL
and switch to the Production URL, followed by moving “back to canvas”
If I go back to the webhook node,
it reverts back to test URL
This is just the display.
The Production URL is active once the workflow is active.
The Test URL is only active when Listen for test event is clicked in the webhook node.
