I’ve just started to see “queued” execution status in addition to “waiting”.
Is it something to do with delay’s set in a workflow?
Debug info
core
n8nVersion: 1.54.2
platform: docker (self-hosted)
nodeJsVersion: 20.15.0
database: postgres
executionMode: scaling
concurrency: -1
license: community
consumerId: unknown
storage
success: all
error: all
progress: false
manual: true
binaryMode: memory
pruning
enabled: true
maxAge: 336 hours
maxCount: 10000 executions
Generated at: 2024-08-15T18:04:00.491Z
n8n
August 15, 2024, 6:05pm
2
n8n version:
Database (default: SQLite):
Operating system:
Debug info
core
n8nVersion: 1.54.2
database: postgres
concurrency: -1
license: community
consumerId: unknown
storage
success: all
error: all
progress: false
manual: true
binaryMode: memory
pruning
enabled: true
maxAge: 336 hours
aya
August 16, 2024, 1:07pm
4
Hi @StocktonF thanks for posting!
That’s my understanding! Hope that helps.
Hey!
sounds very interessting. What is the actual concurrency limit for parallel workflows and where can I change it? Use 1.54.4 OnPrem
Thanks in advance!
Cheers
aya
August 22, 2024, 2:54pm
6
Hi @Olexiy_Zalevskyi , n8n doesn’t set any concurrency limits by default if you use a self-hosted version of n8n in regular mode. But you can change this by setting the N8N_CONCURRENCY_PRODUCTION_LIMIT
env variable. You can find more info here: Concurrency control | n8n Docs
system
Closed
September 17, 2024, 4:29pm
7
